Page 13 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 121 to 130 of 322
Thread: 1974 XS/TX650 rebuild
  1. #121
    Oct 2015
    th62's Tools
    Nope, the cam doesn't. Use a woodruff, instead Yamaha used a round pin inserted through a hole in the shaft.
  2. #122
    Oct 2015
    th62's Tools
    Take three on ignition switch placement. I decided to place it here, under the thank: Less noticeable both on the switch side and the back of the switch. The Delrin cover I made for it hides it reasonably well. Who would think such a simple decision would be so difficult.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-img20210511173033.jpg   1974 XS/TX650 rebuild-img20210511173022.jpg
  3. The Following User Says Thank You to th62 For This Useful Post:
    greenie (May 13, 2021)
  4. #123
    Aug 2020
    Might be a good solution to keys and keyfob rubbing on triple clamps and ruining the paint and/or finish of lacquer.
  5. The Following User Says Thank You to asterix For This Useful Post:
  6. #124
    Oct 2015
    th62's Tools
    Learnt something today: When I bought this POS it had aluminium mags on it, plus it had a spare set of spoked wheels. I was going to use the spoked wheels on this build, until I discovered the price of stainless spokes, $250. So in an effort to save some money I thought I'd use the mags, so pulled out the front wheel and polished up the bared aluminium prior to painting it black. When I pulled the rear wheel out to polish I thought that looks really small, so I checked on the sidewall - 16". Grrr, no good for a cafe racer, so I wasted all that time polishing the damn wheel. So, $250 for spokes it is, damn, damn, damn!
  7. The Following User Says Thank You to th62 For This Useful Post:
  8. #125
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    Quote Originally Posted by th62 View Post
    With the cost of vintage bike parts going crazy over the last 10+ years, I bet you could pay for your spokes and maybe more if you polish the other mag and put them on ebay. Especially with these being popular bikes for all fashion of builds. A few years back I needed a cylinder for a 1979 Yamaha IT250F I was restoring... It was crazy what people were asking, AND GETTING, for absolute junk. Ebay has made restoration and project bikes much easier to put together, however the prices have went crazy, but I digress.....
    Great build by the way, I am always excited to see what you've done next when I see a notification for this thread.
  9. The Following 2 Users Say Thank You to Rikk For This Useful Post:
    asterix (May 12, 2021), greenie (May 13, 2021)
  10. #126
    Oct 2015
    th62's Tools
    Thanks for the critique. I have quite a few parts I'll put up for sale at some time: Battery carrier, side panels, carbs, wheels, wiring looms (one brand new, came as a spare with the bike?), switchgear. I did try to sell locally, pick up only, but all the replies came from interstate, so at some time, I'll have to look at postal fees I guess.
  11. The Following User Says Thank You to th62 For This Useful Post:
  12. #127
    jdurand's Tools
    If you're in the USA, look into https://xpsship.com/ we used them with our business for some time, normally better rates than we could find elsewhere. No special requirements, either a credit card or a bank account with get you going and then you can ship by different shippers at commercial discount rates.
  13. #128
    Oct 2015
    th62's Tools
    Slack day today, just made up a few static timing lights of different design. First one uses a 9 volt battery, so had to solder a resistor in the line to cut the voltage down. Second one works off the bike battery, so also had to use a resistor. Third one uses a 3 volt button battery, so, so resistor required. Why so many? I was bored!
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-img20210515152956.jpg   1974 XS/TX650 rebuild-img20210515152923.jpg   1974 XS/TX650 rebuild-img20210515153031.jpg   1974 XS/TX650 rebuild-img20210515153116.jpg   1974 XS/TX650 rebuild-img20210515153959.jpg
    1974 XS/TX650 rebuild-img20210515153854.jpg
  14. The Following User Says Thank You to th62 For This Useful Post:
    greenie (May 15, 2021)
  15. #129
    jdurand's Tools
    Does anybody really know what time it is?
  16. #130
    Oct 2015
    th62's Tools
    Well, another day spent on the points cam, must have made about a hundred of these bloody things before I figured out how to do it" cut the keyway first, then mark where the ramps are then file, check, file, check, ad nauseum! Finally got it right, close enough to say spot on, statically at least. I also added a felt oiler bracket to the backing plate and moved the condenser up near the coil. Looks a lot neater now, and quicker to set the points with only one set. I don't like cutting key ways on the lathe, so I used a 2mm end mill on the mil. The key is a 2.5mm round pin suck in the shaft crossways, so only had to cut the keyway down around 6mm.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-img20210518094936.jpg   1974 XS/TX650 rebuild-img20210518095030.jpg   1974 XS/TX650 rebuild-img20210518104759.jpg   1974 XS/TX650 rebuild-img20210518103442.jpg   1974 XS/TX650 rebuild-img20210518104530.jpg
    1974 XS/TX650 rebuild-img20210518105921.jpg   1974 XS/TX650 rebuild-2points.jpg
  17. The Following User Says Thank You to th62 For This Useful Post:
    asterix (May 18, 2021)
