Results 1 to 10 of 17
Thread: 3Hp hydraulic power unit
    Actually this would fall under the sub forum tools in progress but I think that one is gone.
    After building my plate roller rather than press it straight into service I decided that I wanted to power it hydraulically.
    This meant that I either had to dig through 10 tons of stuff still stashed away in 1 of my storage trailers to try and find where I had put my power unit or build another.
    To build another was the easier choice First I started with an old automotive lift power unit off of a larger lift actually it was one I had removed from an elevator I built 20 years ago when the coupling went bad a few years back.
    I made a new pump to motor coupling "see Pump/ motor shaft coupling
    Then I inspected several pumps that I had and checked the motor, then located a 4 way valve the one I decided to use is a 3 bank valve I will cap 2 of the sections for now but may need them when I use this power unit to test other equipment.
    next was to decide on a tank the 6 gallon plastic tank didn't fit my design criteria, so I settled on a 15 gallon steel drum it has a good diameter to height ratio being almost the same in height as in diameter.
    I couldn't just mount the pump and motor directly to the top as the metal was too thin for my liking so I cut 3 old truck mud flaps to fill the depression in the top Then I needed to cut a round plate to cover these with and bolt through everything.
    this was why I made the Simple plasma torch circle guide to cut out the round piece
    here are some assembly pictures I still need to make up 3 hoses tomorrow if I have the correct fittings then will have to wait until I need to make a trip to town to get the oil.
  2. The Following 13 Users Say Thank You to Frank S For This Useful Post:
    Andyt (Aug 21, 2019), baja (Aug 21, 2019), Christofix (Aug 20, 2019), clydeman (Jan 10, 2023), Crusty (Aug 20, 2019), HandymanNSons (Aug 26, 2019), Jon (Aug 22, 2019), KustomsbyKent (Aug 20, 2019), Little Rabbit (Aug 8, 2022), mwmkravchenko (Jun 22, 2024), NortonDommi (Aug 27, 2019), Scotty12 (Aug 20, 2019), Seedtick (Aug 20, 2019)
