Results 1 to 10 of 16
Thread: Center Punch Guide
  1. #3
    Dec 2013
    Florida
    rossbotics's Tools
    Thank you for compliment LMMM
    The reason for the 60° point is for visual purposes, that little bit of angle difference greatly increases the visual of locating the point of the center punch, I have always used a small pilot drill of no more than 3/32" to start with, then open the hole in increments to the final size, I am very aware of the proper 90° for a common center punches, even the common hand held center punches I have also have a steeper angle than 90° for that visual purpose, I agree that if someone wanted started with a 1/2" bit would create a walking problem.
    Thanks for bringing that up LMMM I should have mentioned the small pilot drill is necessary first then open up the hole in increments.
    Cheers LMMM
    Comments are always welcome
    Doug
  2. The Following User Says Thank You to rossbotics For This Useful Post:
    Paul Jones (Jul 24, 2017)
