Results 1 to 7 of 7
Thread: DIY air separator
    Oct 2019
    Sgbarker's Tools
    DIY air separator
    This is a homemade air separator for my plasma cutter and sandblast cabinet. I made it portable so that I could use it at either the plasma cutter or the sandblast cabinet. Also allows the air more time to cool down from the compressor before it gets to the separator. It seems to work pretty good, check it out!
  2. The Following 20 Users Say Thank You to Sgbarker For This Useful Post:
    57_210 (Mar 14, 2023), Altair (Jan 2, 2020), Baddog (Jan 6, 2020), baja (Jan 4, 2020), Canyonman44 (Jan 4, 2024), Corm (Jan 4, 2020), davesrepair (Aug 9, 2024), emu roo (Aug 9, 2024), freddo4 (Jan 3, 2020), GedB (Jan 6, 2020), ibdennyak (Jan 3, 2020), Jon (Jan 3, 2020), mwmkravchenko (Jan 4, 2020), n9dug (Jan 6, 2020), Rangi (Jan 5, 2020), rlm98253 (Jan 3, 2020), that_other_guy (Aug 9, 2024), Tonyg (Jan 4, 2020), Toolmaker51 (Jan 10, 2020), Tule (Jan 6, 2020)
    Thanks Sgbarker! We've added your Water Separator to our Air Compressors category,
    as well as to your builder page: Sgbarker's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to Altair For This Useful Post:
    Sgbarker (Jan 5, 2024)
    Apr 2016
    Centurion, South Africa
    Nice build, I like the portability.
  6. The Following User Says Thank You to Tonyg For This Useful Post:
    Sgbarker (Jan 11, 2020)
    Congratulations Sgbarker - your Water Separator is the Homemade Tool of the Week!
    Difficult week to win around here, with many high-quality entries.
    Tubing Beader by tony b
    Rivnut Tool by Salix84
    Power Pack by garage nut
    Lathe Multi Stop by thehomeengineer
    Draw Rod Tool by garage nut
    Desk Lamp by bobs409
    Variable Height V-Block by rgsparber
    Glass Bottle Cutter by Kwandotechnic
    Welding Third Hand by bobs409
    Rope Splicing Fid by Downeast Thunder
    Slip Roller by superskypilot
    Rotary Welding Positioner by bobs409
    Workbench Bar Clamp by Kwandotechnic
    Soldering Iron Saver by garage nut
    Box Tools by greenie
    Open Blade Sheath by mklotz
    Off Size Drillling Method by kess
    Cove Jig by Make Things
    Rotary Welding Table by bobs409
    Divider by Eloy Workshop
    Ultimate Table Saw by Didpoolhall
    Vise Refererence Fence by garage nut
    Router Table by woodenworldenic
    Mill Drill Clamping Table by House_Work
    Sgbarker - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
    You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
    Nice work!
    Very nice. And copper is not only safe for compressed air, it should conduct heat away from air better than black or galvanized pipe.
    I'd add two things. A small separator at inlet; plexi bowl would make accumulation visible. Using petcocks or needle valve drains instead rather than ball valves, being easier to 'crack' open.
    But it works! Not only Portable but Attached; big step saver.
  9. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  10. #6
    Oct 2019
    Sgbarker's Tools
    Thanks! That’s awesome! I really enjoy sharing! And everyone is very supportive!
  11. #7
    Mar 2012
    Western New York
    Just a thought before you paint the copper. I think it would probably work better with no paint on it as copper is a good conductor of heat and would probably help it do its job better without paint at it. I also like the idea of petcocks for drainage. Just my 2 cents. Nice build.
