Results 1 to 10 of 37
Thread: Homemade Lathe Headstock EXTERNAL Gearbox
  1. #26
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Update / Upgrade
    In order to upgrade this gearbox and make an overkill, I have alredy ordered and received 2 gears; 33 and 55 teeth.
    Paid total 3.73 USD for both of them. Picture of speed chart together with new gears attached.
    I also decided to install recirculating pump and prevent "churning".
    Will buy recirculating pump together with tank, pumping capacity 1.2 liters per minute. Price up to 25 USD max.
    Picture attached.
    Google translated from Chinese:
    Taiwan genuine 1.2L liters / 1.8 liters electric lubricant pump / CNC electromagnetic pump / machine automatic oil pump
    It can be found on the following web pages:
    https://item.taobao.com/item.htm?spm...cket=12#detail
    Will also buy 2 distributors for copper pipes; each 8 lines and will have 8 lines for gears and 8 lines for 8 bearings.
    Picture attached.
    B type adjustable resistance proportional distributor / TK oil distributor / oil / oil valve / lubrication branch
    Picture attached and it can be found at the following web pages: Check the prices.......
    https://item.taobao.com/item.htm?spm...id=44406509307
    Best regards
    LMMasterMariner
ID:	23757   Click image for larger version.
Name:	recirculating pump n tank.jpg
ID:	23758   Click image for larger version.
  2. The Following User Says Thank You to LMMasterMariner For This Useful Post:
    Jon (May 15, 2018)
