Congratulations tonyfoale - your Cross Slide Screw Conversion is the Homemade Tool of the Week!
This is a unique and well-explained modification, and your second Homemade Tool of the Week win in a row. Nobody has ever won three Homemade Tool of the Week awards in a row. Previous two-in-a-row winners are:
Brendon in 2015: Marking Gauge and Dovetailing Bench
mklotz in 2016: Bench Block Enhancements and Model Cement Mixer
tonyfoale in 2016: Horizontal Milling Machine and Drum Brake Grinder
rossbotics in 2017: Tilting Dividing Fixture and Dial Indicator Attachment, and again for Center Punch Guide and Deburrer
thehomeengineer in 2018: Ring Roller and Axle Stands
Stevohdee in 2018: Milling Machine Power Feed and Tool Post Grinder
Mark Presling in 2019: Demagnetizer and Quick Change Indicator Holder
Shear Tool by olderdan
Radius Turning Attachment by ttmrj
Rose Index Block by N4NV
Mill Spindle Plans by engineer steve
Mill Riser Block by tmate3
Clamp by orioncons36
Shear Tool by DIYSwede
Paint Removal Method by HandmadeCreativeChannel
Dial Indicator by machining 4 all
Spring Fuller by Philip Davies
Log Splitter Engine Replacement by IntheGroove
Gerson Hammer by IntheGroove
Drill Press Drill Bit Adaptor by HandmadeCreativeChannel
Wood Burning Stove and Heater by Mr.DK DIY
Gas Cylinder Wrench by Don42
Industrial Jointer Mobile Base by tiger carpenter
tonyfoale - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
This is your 12th Homemade Tool of the Week win! Here are all of your winning tools:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/home-made-horizontal-milling-machine-55333#post81620"> <img src="/uploads/162905/homemade-horizontal-milling-machine-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/home-made-horizontal-milling-machine-55333#post81620">Horizontal Milling Machine</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/mill'>mill</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/grinding-machine-drum-brakes-55587#post82147"> <img src="/uploads/162657/homemade-drum-brake-grinder.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/grinding-machine-drum-brakes-55587#post82147">Drum Brake Grinder</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/grinder'>grinder</a>, <a href='https://www.homemadetools.net/tag/brake-drums'>brake drums</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/shock-dyno-shock-absorber-dynamometer-56478#post83755"> <img src="/uploads/163993/homemade-shock-absorber-dynamometer.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/shock-dyno-shock-absorber-dynamometer-56478#post83755">Shock Absorber Dynamometer</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/suspension'>suspension</a>, <a href='https://www.homemadetools.net/tag/measurement'>measurement</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/valve-holding-measuring-collet-58294#post87183"> <img src="/uploads/166061/homemade-valve-holding-collet.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/valve-holding-measuring-collet-58294#post87183">Valve Holding Collet</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/valve'>valve</a>, <a href='https://www.homemadetools.net/tag/holder'>holder</a>, <a href='https://www.homemadetools.net/tag/collet'>collet</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-laser-aligner"> <img src="/uploads/168729/homemade-laser-aligner.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-laser-aligner">Laser Aligner</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/alignment'>alignment</a>, <a href='https://www.homemadetools.net/tag/laser'>laser</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/double-edged-fly-cutter-63995#post100445"> <img src="/uploads/205514/homemade-double-edge-fly-cutter.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/double-edged-fly-cutter-63995#post100445">Double Edge Fly Cutter</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/flange'>flange</a>, <a href='https://www.homemadetools.net/tag/fly-cutter'>fly cutter</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/homemade-vertical-bandsaw-66678#post108045"> <img src="/uploads/211089/homemade-vertical-bandsaw-5.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/homemade-vertical-bandsaw-66678#post108045">Vertical Bandsaw</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/bandsaw'>bandsaw</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/diy-surface-grinder-67127#post109600"> <img src="/uploads/212251/homemade-surface-grinder-11.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/diy-surface-grinder-67127#post109600">Surface Grinder</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/grinder'>grinder</a>, <a href='https://www.homemadetools.net/tag/surface'>surface</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/radius-gauge-reverse-engineering-70673#post123621"> <img src="/uploads/219843/homemade-radius-gauge-3.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/radius-gauge-reverse-engineering-70673#post123621">Radius Gauge</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/gauge'>gauge</a>, <a href='https://www.homemadetools.net/tag/radius'>radius</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-motorcycle-chassis-what-tools-75470#post142830"> <img src="/uploads/226725/homemade-motorcycle-frame-fabrication.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-motorcycle-chassis-what-tools-75470#post142830">Motorcycle Frame Fabrication</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/motorcycle'>motorcycle</a>, <a href='https://www.homemadetools.net/tag/frame'>frame</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/treadmill-motors-my-modifications-83472#post173733"> <img src="/uploads/242690/homemade-treadmill-motor-modifications.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/treadmill-motors-my-modifications-83472#post173733">Treadmill Motor Modifications</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/safety'>safety</a>, <a href='https://www.homemadetools.net/tag/modification'>modification</a>, <a href='https://www.homemadetools.net/tag/motor'>motor</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/lathe-cross-slide-conversion-ball-screw-83598#post174256"> <img src="/uploads/243474/homemade-cross-slide-screw-conversion.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/lathe-cross-slide-conversion-ball-screw-83598#post174256">Cross Slide Screw Conversion</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='https://www.homemadetools.net/tag/modification'>modification</a> </div> </div> </div> </div>
