Results 1 to 4 of 4
Thread: Ratchet tap wrench with automatic reversing clutch.
Hybrid View
    Supporting Member Mook's Avatar
    Sep 2023
    UK
    Mook's Tools
    This tap wrench is designed to remain locked during normal operation, ensuring a positive drive. The ratchet is always readily available. However, many tapping situations benefit from a ratcheting function to make the process faster and easier.
    Conventional one-way clutches have a major limitation — they prevent reversing the tap for chip breaking or removal. To overcome this, I developed a mechanism where the clutch engages automatically with downward handle pressure.
    When reversal is needed, simply reduce the applied pressure. The clutch disengages instantly, allowing the tap to move in the opposite direction while remaining locked and concentric.
    The result is a tap wrench that’s intuitive, efficient, and far more versatile than traditional ratchet designs.
  2. The Following 7 Users Say Thank You to Mook For This Useful Post:
    DIYer (Oct 2, 2025), emu roo (Oct 2, 2025), Harvey Melvin Richards (Oct 2, 2025), Improvised DIY (Oct 12, 2025), Jon (Oct 2, 2025), PJs (Oct 5, 2025), sossol (Oct 2, 2025)
    Congratulations Mook - your Ratchet Tap Wrench is the Homemade Tool of the Month for October 2025!
    Tough month to win, and definitely not the first homemade tap wrench we have seen over the years. However, this is one of the best designs, especially considering Mook's followup Refined Design Ratchet Tap Wrench.
    And that makes two Homemade Tool of the Month wins for Mook, after his Work Support from last August.
    Some more good builds from October:
    100 Ton Press by Frank S
    Flexible Driveshaft by hemmjo
    Thin Wall Heat Glue Sheets by rgsparber
    Lifter Tester by tonyfoale
    Bench Grinder Modifications by Dr.Al
    Paint and Work Lights by Frank S
    Belt Sander Lathe Mount by hemmjo
    Box Joint Jig by RCTURKA
    Wire Unroller by BuffaloJohn
    Angle Setting Jig by Make Things
    Trunnion Ball Socket Gauge by Frank S
    Knurling Tool by troyhaack
    Marking Knives by Philip Davies
    Electric Trolley by Kwandotechnic
    Router Bed Modification by Cazual Haze
    Raised V-Blocks by Improvised DIY
    Log Sawing Jig by Mazay
    Supplementary Coolant Systems by The Outback Shed
    Ball Turner by Occasional machinist
    Motorcycle Lift Stand by Liquidhandwash
    Lawn Tractor Trike by warsztatOdZera
    Mook - You'll be receiving a $250 cash prize, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and prize choice and I'll get it sent over right away.
    Nice work
  4. The Following User Says Thank You to Jon For This Useful Post:
    emu roo (Nov 18, 2025)
