Results 11 to 14 of 14
Thread: Re-think on wire bender for making chain links
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    After posting the wire bender to make the chain links using a M8 nut and bolt, Wire bender for making small chain links for model traction engine steering chains I wasn't totally happy with the shape of the links and how fiddley they were to produce. So this was playing on my mind , I had to think of a better way to form the links, and I couldn't find anything on the net on how to form small chain links . So after a few days contemplating the best way forward I put pen to paper (yes a PEN with real ink) and started to play around with some ideas on how to improve the shape and production of these tiny links.
    As I need to make approximately 120 links for the steering chains on my 1" scale traction engine I also wanted to be able to cut the wire to a constant length so also designed and built a wire cutting guillotine (I will post on HMT in another post)
    Below are the photos and results of the new wire bender:
    Photo of the completed tool and the first few links bent on it.
Name:	IMG_4479 completed link 2.jpg
ID:	33389 Click image for larger version.
Name:	IMG_4478 complete link.jpg
ID:	33391 Click image for larger version.
Name:	IMG_4480 datum.jpg
    The bender forms the wire link in two stages around the pin located on the centre line of shaft. The length of wire was calculated to be 13.8mm and a datum mark was set on the shaft with a small chisel mark at approximately 7mm from the centre of fully formed link so the joint would be in the middle of link. (mark highlighted on photo).
Name:	IMG_4482 linked together.jpg
    First links fitted to each other
Name:	IMG_4483 chain linked.jpg
    new link shape is a lot more pleasing on the eye (in my opinion)
Name:	size of link old.jpg
ID:	33396 Click image for larger version.
Name:	IMG_4435 2nd bend.jpg
    Old former also didn't close the link fully.
    Old link shape using nut and bolt wire bender has square ends due to the way the former was made.
    As the wire is only 1mm 0.040" diameter and copper it is easy to bend.To aid the movement I didn't feel it was necessary for a handle so I simply knurled the out diameter to give grip when rotating. The Bender guide also acts as location and stops the outer from sliding all the way down the central shaft.
    I am very happy with the shape and have gone into full production
    thank you for viewing
    The Home Engineer
ID:	33390   Click image for larger version.
Name:	IMG_4480 first link.jpg
  2. The Following 21 Users Say Thank You to thehomeengineer For This Useful Post:
    asterix (Jun 11, 2022), baja (Feb 6, 2020), bobs409 (Feb 3, 2020), brianp (Feb 7, 2020), Canobi (Feb 8, 2020), Christophe Mineau (Feb 4, 2020), emu roo (Jun 23, 2025), Inflight (Jun 16, 2023), Jon (Feb 3, 2020), Kevic (Feb 7, 2020), Little Rabbit (Feb 5, 2020), mr herb (Feb 9, 2020), Okapi (Feb 6, 2020), Paul Jones (Feb 4, 2020), Philip Davies (Feb 6, 2020), rlm98253 (Feb 4, 2020), Scotty12 (Feb 5, 2020), Sleykin (Feb 8, 2020), thevillageinn (Feb 10, 2020), threesixesinarow (Feb 4, 2020), Tonyg (Feb 6, 2020)
