Page 10 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 LastLast
Results 91 to 100 of 227
Thread: Rotary Phase Converter (Create 3-phase power from a single phase source)
  1. #91
    Supporting Member smithdoor's Avatar
    Clovis CA
    Is this for single to three phase ???
    Dave
    Quote Originally Posted by nhengineer View Post
    Mr. Kodger,
    After sleeping on it for a bit, I believe an isolation transformer transformer may (or may not) be your wisest choice. Immediately below is a watts to HP chart which should be useful in sourcing a proper transformer.
    Attachment 16180
    Next is finding a transformer with the proper KVA rating. For 3HP you'd need about 2400Watts so I quickly looked at the Newark catalog.
    http://www.farnell.com/datasheets/18...440.1484843408
    Attachment 16179
    The cost is around $450 US plus shipping. The transformer above is NOT the exact one but it is representative of the device you'd need for 3.0HP. If you'd like for me to try and find the exact one let me know. It is not totally unlikely that you may need two transformers to do what you need to do.
  2. #92
    Supporting Member nhengineer's Avatar
    Aug 2016
    nhengineer's Tools
    Mr. Kodger,
    Attachment 16180
    Attachment 16179
    $700 US FOB Anaheim, CA, USA and you'd need to fabricate your own enclosure.
    Rotary Phase Converter (Create 3-phase power from a single phase source)-lcmagneticstransformerquotation.jpg
  3. #93
    Clovis CA
    How are using this transformer
    I was thinking this for single to three phase
    Most motors that are 415 volt can also be wire 240 they wye/delta wound motors
    I think take close look at the motor to see what type it is most wye delta motor are 6 wire type
    Dave
  4. #94
    Oct 2016
    old kodger's Tools
    Rhengieer,
    I thank you for your effort, but now you see what I mean when I say, in Australia most of the options to date are totally uneconomic, for instance, I need to power a 3 phase mig welder which is name-plated at 10 amps per phase which is about 7.1kw at 230 volts. If a 3hp transformer is likely to cost $450 US that's around $600 AU, and I might need two...$1200 plus freight, and as I mentioned before freight from the US to AU needs the surrender of ones first born, I would not be surprised to find that the freight exceeded the initial cost of the transformers. Also 3hp would woefully inadequate, I need at least 10 amps per phase, for a overload margin, maybe more.
    So at a potential cost in excess of $2400, a second hand 3 phase generator is starting to look a lot more realistic.
    I thank you for all your effort, and indeed to all the other contributors to this thread, but unless I can find a way to control a synchronous motor acting as a generator, I have two options:- buy a generator or attempt to rewire the welder to run on single phase. Incidentally, I'm informed by the manufacturers of the welder, that the configuration internally is actually three separate transformers feeding a bank of full wave bridges, so it could be possible.
    If anyone is interested I'll keep you informed.
    Rob.
  5. #95
    Clovis CA
    That will work for your
    Good luck
    Dave
    Quote Originally Posted by old kodger View Post
    Rhengieer,
    Rob.
  6. #96
    Rhengieer,
    Rob.
    Not knowing which machine you have so I cannot tell you that yes it is possible however most of the older 3 transformer machines can actually be re wired to run on single phase the issue in your case may be having the only 1 hot single phase type current. THat being said you might crawl down this rabbit hole and have a go at a rather long thread where some guys have converted some 3 ph mig welders to run on single phase
    Miller CP-250TS converted to single-phase
  7. #97
    Clovis CA
    Like your thinking Frank low cost too
    The only item on welder is in some cases the cooling is 3-phase still low cost to change with off the shelf fan. I do not see a fan on the Miller CP-250TS
    In worst case it no change it would only be 2/3 the amperage.
    Dave
  8. #98
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Make up a number to give them.
    I can't get into YAHOO groups anymore without giving up my cell number and that's not going to happen; not to YAHOO. How about you, Smithdoor, upload that file to your PC and then download here?
    DSLee
  9. #99
    Mar 2014
    Beaumont, TX
    Smithdoor, and everybody else,
    I am fully, completely, and absolutely aware that the power supplied to most households in the US, including mine, is universally called SINGLE PHASE or split phase. And I am aware of WHY this terminology is used. There really is no reason to try to argue with me about this. As far as common usage is concerned, I do concede that point.
    BUT, when most three phase converters use this split phase, "single phase" 230 Volt household source to create three phases to run a motor, they only create ONE additional line. So, they take this three wire, split phase, single phase supply and add only one wire and bingo, they have three phases. And the ground wire from the original split phase supply is NOT one of them. Freaking magic! Add one to one and you get three. WOW! What a concept.
    At the output of the phase converter you have three phases: split phase #1, split phase #2, and the new phase that is generated by the circuitry of the converter. In understanding this feat of magic, that third phase and I don't mean the one generated by the circuitry in the converter, has to come from somewhere. It wasn't really magic, it was one of those original "split" phases. And there were two of them. I, in my scientific brain call that a two phase feed. TWO distinct phases are already present in what the entire electrical power business in the US calls "single phase" or "split phase". They really are there: TWO of them really are there. They really are not in phase with each other so, in reality, they really are TWO distinct phases to begin with.
    The real mystery is how can they be 180 degrees out of phase with each other at the supply line coming into the house and then, after passing through the phase converter with nothing but metallic paths inside that converter, they suddenly are only 120 degrees out of phase when they get to the motor you/we are trying to supply with three phase power. Phasing magic! For a long time I believed that the output of a simple phase converter was actually three phases that had a 90-180-90 phase relationship. It took me a while to realize what was actually going on there. But it is real and it does work. And they really are 120 degrees apart at the motor (120-120-120). If you want to argue with my use of terminology, then you explain that FACT. Hint: it helps if you open up your mind to the idea that they really are TWO PHASES in the first place, not just one. I await your explanation.
    I have never read a really understandable explanation of this that does not involve many pages of complex math., usually chapters of them. I have made a mental note to try to write a simple and concise explanation that all can understand without integrals or vector math, but I am not sure it can be done. I have a daughter who taught college level physics and I may enlist her help in this. She liked to come up with new ways to make things understandable. I had to work it out with vectors and I had to go over it several times before I was convinced that it was correct.
    Quote Originally Posted by smithdoor View Post
    You find more information on why this does not work from the book publish by Lindsay Publications (How to run three phase motor) I can not post it here as has copyright of 1977 and 1987.
    You find this book on the web see pages 4 5 & 6 It does not have any charts for making one. Try this site https://groups.yahoo.com/neo/groups/...ndlathe9/files
    Dave
  10. #100
    There have been 10 pages of comments here sometimes it appeared to me that the ultimate solution to an individuals problem was running off of the rails, However the main topic has been to come up with a working plan to have 3 ph power where none is readily available. Then there is the economics side of the situation. " nhengineer" has in my personal opinion been quite diligent in his personal research to this as well. Every time myself or others have opened different avenues of approach he did his own research for the feasibility of our ideas. I believe it requires one to have a very open mind to accept that there are sometimes many problems to 1 solution as well as the counter side many possible solutions to a given problem, and while personally I know that I can construct my own Rotary phase or a static converter from knowledge and experience gained over the years I'm going to purchase a set of his plans even though I do not need them. My view on this is it never hurts to have more information.
