Results 1 to 10 of 18
Thread: Socket wrench for toilet oval water shutoff valve
    May 2016
    Don42's Tools
    The fill valve on my toilet has a slow leak. That’s the one that a float is supposed to shut off when the tank refills. Mine doesn’t quite shut off. It dribbles a little.
    In order to replace it, I need to shut off the water feed to the toilet. That’s one of those little valves with the oval handles.
    Like most plumbing opportunities, It’s in a place that’s awkward to get at – and like most older things (including me) it is very stiff. I can’t turn it with my bare hand and I can’t quite get a pliers or wrench on it. So today, rather than fixing the toilet as was my plan for today, I made a tool. It’s an oval socket wrench to fit the handle of an oval-handled toilet valve.
ID:	34849 Click image for larger version.
    I cut a slightly oversized oval out of 1/8” steel and shaped it with the belt sander. Then I cut a 6” piece of 1/8 x 3/4 steel, welded one corner of it to the side of the steel ellipse. Then, while heating it to orange heat with an oxy-acetylene torch I bent it around the oval until it enclosed the oval. Then I welded it all round to the ellipse and welded the ends together. Then I cut off a piece of ¾” hex stock and welded that to the ellipse from the inside. I'd turned a 1/2" boss on it that goes thru a 1/2" hole in the oval. The hex will fit a 3/4" socket on the end of a long extension and driven by a 1/2" ratchet wrench.
  2. The Following 14 Users Say Thank You to Don42 For This Useful Post:
    baja (May 6, 2020), benkeller3 (May 11, 2020), blkadder (Feb 19, 2023), Carnel (May 6, 2020), Jon (May 5, 2020), llh49 (May 6, 2020), olderdan (May 5, 2020), Paul Jones (May 10, 2020), PJs (Jul 7, 2024), Ralphxyz (Jul 7, 2024), rlm98253 (May 9, 2020), Sleykin (May 12, 2020), thevillageinn (May 5, 2020), Toolmaker51 (May 6, 2020)
