Results 1 to 10 of 14
Thread: Trailer motor mover
  1. #4
    Apr 2012
    NorCal
    Saltfever's Tools
    Nice build and thanks for sharing. Great pic quality too!
    Since its a solid axle do you feel resistance to tight turning? Or, are your turns limited? Since the load is located between front and back wheels, I assume no tipping force at rest. Do you feel it tipping when applying drive torque? Do you feel you need a lock to control it? What is your overall gear ratio and diameter of the drive tires?
    Sorry for all the questions. I need one of these too.
    PS: That is an interesting winch. Did you modify it to locate the sprocket in the middle? What application is it used for?
  2. The Following User Says Thank You to Saltfever For This Useful Post:
    thehomeengineer (Aug 3, 2024)
