Toolmaker 51 was referring to the cranes in the building. He and I have gained the ability to see each other's thought which may not otherwise been fully explained. we do joke with each other quite a bit.
the purlins are 6 x 2 C purlin 30 feet long and 4 x 1 1/2" c purlin 30 feet long there were 10 pieces of the 6 inch and 5 of the 4 inch additionally there was 1 6" connector sleeve channel 25 feet long and 1 4 inch connector sleeve channel 20 feet long. the total weight was around 1,000 lbs. Not much of a load for the old truck but enough of a load on my wallet for a while. this material will be enough to construct 1/4 of the roof and half of the North wall so in effect I will have a lean to for a while LOL
I may have to invent a trick way to get things installed doing the work largely by myself. Also I will have to fix some straps or clips to hold the 4 b8 panels of insulation in place between the purlins before I put the sheet metal on the roof the sheets are 36 ft long that in itself will be a challenge at least for the first couple of sheets
Yes the purlins will be welded in place with angle clips as well and bridging straps to prevent what is known as rollover buckling.
