Results 1 to 10 of 21
Thread: rotary table driven by stepper motor controlled by 2 Arduino's
    Berkshire UK
    thehomeengineer's Tools
    hi All
    I have finally attached the stepper motor and encoder and had the rotary table moving.
    After testing there are a couple of issue that need attention 1st being the variable feed/speed control via a potentiometer. When turned to full rotation it stalls the motor. 2nd I need to check the coupling is tight on the motor shaft and the control box wiring is somewhat messy and will need tidying but as this is the first time I have ever taken on a project like this. It was very much a, make it up as you go along just to get it working and then worry about the presentation at the end.
    The main control is via a Arduino Mega and TB6600 motor controller and the encoder uses a Arduino Nano.
    I did have a lot of help with the programming. Without this help, I don't think I would have completed the project with all the features I wanted.
    The control box has four modes. Degrees, Divisions, Jog and Feed. The Feed is controlled via a potentiometer, which I want to change how this controls the table.
ID:	33045 Needs a little tidying
Name:	setup sequence.jpg
ID:	33046 Start up
ID:	33047 Options that can be selected
ID:	33050 Degrees selected
ID:	33048 Selection set to 20 degrees and ready to move table.
ID:	33049 Angle travelled and small top screen shows position via encoder. Very pleased with accuracy.
Name:	stepper motor adaptor plate.jpg
ID:	33051 Aluminium adaptor plate to connect stepper motor to table
ID:	33052 Click image for larger version.
Name:	motor inplace.jpg
ID:	33053 Motor and encoder in place
    This project was a steep learning curve with many mistakes made some expensive It has been very interesting and frustrating at the same time, but as previously mentioned without the help of a very clever electronics apprentice where I work, I would have struggled to complete this project. So a massive thank you to him.
    I have added some links below which are also linked to this project which I think has been roughly a 6 months in the making.
    Links:
    https://www.homemadetools.net/forum/rotary-table-re-ferb-ready-stepper-motor-75765
    rotary table worm shaft
    Comparing worm shaft depth with three wire method
    Rotary table stepper motor encoder mounting plate and encoder bore reducer
    Stepper motor encoder cover
    Thank you for taking the time to view.
    The Home Engineer
  2. The Following 18 Users Say Thank You to thehomeengineer For This Useful Post:
    albertq (Mar 22, 2024), bobs409 (Jan 14, 2020), byates (Jun 1, 2023), DIYSwede (Jan 10, 2020), Duke_of_URL (May 29, 2023), emu roo (Jul 20, 2022), garage nut (Jan 11, 2020), high-side (Jan 13, 2020), Home-PC (May 30, 2023), Jon (Jan 10, 2020), Mr Mechanical (Jan 14, 2020), mwmkravchenko (Jan 13, 2020), Paul Jones (Jan 15, 2020), Ralphxyz (Jul 24, 2022), Saltfever (Jan 20, 2020), schatten (Jan 14, 2020), tonyfoale (Jul 21, 2022), Tonyg (Jan 16, 2020)
