https://youtu.be/0laJChs61Yo
Nice - gonna do it - I even think I have some threaded ball-detent units.
Super useful idea - the kids have all gotten blood-blisters on their fingers from the handle on the big Reed vise sliding down - I'd just put O-rings on the handle ends as cushions, but this is far better.
Forrest in Atlanta
Simpler way: put an o-ring either side of the central boss.
The handle's far too heavy - it's a Reed 105 S. If you could get it to hold, you'd have to slide (roll) the O-rings back to the center after you've extended the handle to really crank down.
Thanks for that and I will do the same with one slight difference. I’ll machine a groove around the shaft instead of the shallow hole so I don’t have to line up the hole.
Thanks, Stuart
If you machine a grove all way round the center of the bail then the first time you really put a strain on it you are going to bend or snap it in two.
I used to have a huge Prentice vice that I pretzeled the bail so many times I replaced it with a length of 7/8" stress prof and that was without a grove or detent in the middle. And like Forrest said the ball ends would draw blood when dropping
Thanks guys. It's not my original idea, I have seen some American made vices which come with this feature. I just wish I'd done it years ago! I think the O-ring idea would work ok on lighter vices but wouldn't give you the freedom of movement of the handle that this does.
A great idea for larger bench vices.
The indent is not really essential as a stronger spring with a brass pad will retain the handle in any position. I have done this on my drill press handle mod and it works very well.
Attachment 34751
Thanks Retro Steam Tech! We've added your Vise Handle Modification to our Vises category,
as well as to your builder page: Retro Steam Tech's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-vise-handle-modification-2"> <img src="/uploads/233024/homemade-vise-handle-modification-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-vise-handle-modification-2">Vise Handle Modification</a> <span> by <a href="https://www.homemadetools.net/builder/Retro+Steam+Tech">Retro Steam Tech</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/vise'>vise</a>, <a href='https://www.homemadetools.net/tag/handle'>handle</a>, <a href='https://www.homemadetools.net/tag/modification'>modification</a> </div> </div> </div> </div>
Congratulations Retro Steam Tech - your Bench Vise Modification is the Homemade Tool of the Week!
Yet another busy week around here, with many high quality builds. This one wins on not only cleverness but utility too.
Silver Soldering Technique by thehomeengineer
Burr Storage by mklotz
Lathe Chuck Spider by celsoari
Paving Tile Lifting Method by olefella
Grinder, Wire Brush, and Buffer Stand by winkys workshop
Rotary Tool Mounting Fixture by Carnel
Toilet Valve Socket by Don42
Lantern Tool Holder by winkys workshop
Sandblast Gun by Mr.DK DIY
High Torque Drill Press by Es Welding
4-Axis Hot Wire Foam Cutter by m2rechtin
Knurling Tool by garage nut
Sharpening Vise Stand by garage nut
Wheel Dolly by brianhw
Punch Awl by Christophe Mineau
Small Wheel Sanding Attachment by bobs409
Tractor Tire Breaking Method by Frank S
Nakiri Knife by anthonyget
Drill Press Handle Modification by olderdan
Violin Cabinet by SculptyWorks
Belt Grinder Tracking Wheel Mechanism by House_Work
Strap Clamps by bouboulas
Router Lift by HandmadeCreativeChannel
Soft Chuck by Philip Davies
Lathe Workpiece Holder by Philip Davies
Lathe Power Feed by h7eh7e
Machinist's Squares by kwm24@o2.pl
Chisel Handles by Philip Davies
Chop Saw Modifications by Captainleeward
Retro Steam Tech - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
https://www.homemadetools.net/forum/...OfTheWeek4.pnghttps://www.homemadetools.net/forum/...eWeekIcon4.png
You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
Nice work! :thumbsup:
putting o-rings is a simpler way but its not even close to being the same. i have done the o-rings i have used tape, plasticish coatings. but i always go back to drilling and tapping a hole. i have not done the ball and detente i have just used a knob with a threaded post and just tighten it when i need it to stay and loosen it when i want it to move. i will try the detente tonight on a new to me vise. the only issue is sometimes its hard to tap the hole if the handle is not easily removed and is tight in the hole.
I have several vices and I have used and owned many others. The Record vice shown here is the best and the Wilton that I have is the worst.
