Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Hold down clamp from a rocker arm
    I have mentioned these several times in the past but never published one, so today when I found one while rummaging around looking for something else I decided it was time to make one again.
    I started with a rocker arm from a SB gm engine, with a bur file on a die grinder I enlarged the hole to accept a 1/2" T bolt then drilled out the threads from a lug-nut to become the swivel washer
  2. The Following 16 Users Say Thank You to Frank S For This Useful Post:
    baja (Feb 4, 2022), Cascao (Feb 3, 2022), DIYSwede (Feb 3, 2022), emu roo (Jul 29, 2025), EnginePaul (Feb 7, 2022), Hoosiersmoker (Sep 22, 2023), Jon (Feb 4, 2022), neilg4dbn (Feb 6, 2022), NortonDommi (Feb 4, 2022), nova_robotics (Feb 6, 2022), Philip Davies (Feb 7, 2022), rebuilder1954 (Feb 5, 2022), rlm98253 (Feb 3, 2022), Saltfever (Feb 7, 2022), sossol (Feb 4, 2022), Toolmaker51 (Feb 4, 2022)
    Thanks Frank S! We've added your Hold Down Clamp to our Clamps category,
    Marion, Iowa
    metric_taper's Tools
    That looks like the same rocker arm in my 1962 Pontiac 389 V8.
  6. The Following User Says Thank You to metric_taper For This Useful Post:
    the rocker arm clamp works really well I will have to try and find the rest of the ones I know I have squirreled away somewhere and make up a set of them
    I'll be careful what I drive then, for a return visit.........
  10. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  11. #6
    Aug 2016
    wizard69's Tools
    Anything that works and is safe is good by me. I'm trying to put together a small home shop and honestly it is expensive even if you try to DIY a bunch of needed tools.
  12. The Following User Says Thank You to wizard69 For This Useful Post:
  13. #7
    Quote Originally Posted by wizard69 View Post
    Trust me I hate to be the barer of bad news but the more you get into putting together your home shop the more you are going to find things to spend money on. Search for the best deals you can and buy quality tools or tooling even if you have to stretch out buying them over a period of time, it will be cheaper in the long run, when you absolutely cannot or do not have the means or materials make them yourself.
    My theory is buy quality use it forever, buy cheap for emergencies then either try to make it better or plan on replacing it as you can.
  14. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Jul 29, 2025), NortonDommi (Feb 4, 2022), Philip Davies (Nov 16, 2023)
  15. #8
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    Brilliant idea Frank!
    I always replace these halfway through the race season and I generally toss them in the scrap recycling pile. I am pretty sure I have a set of them laying around in a coffee can somewhere complete with the pivot balls. A little machining and I'll have a nice set of "rocker clamps". Thanks for the idea!
  16. The Following User Says Thank You to Rikk For This Useful Post:
  17. #9
    Frank S's theory and practice is exactly correct. There is no savings in bad tools, nor excess tools; unless distributed across different worksites.
    There are limitations for every tool, of course. Frank S's rockers for example are fine in many instances, but not always. The limit is in the design of maybe 1:1.5 to 1:1.6 ratio of clamping, the fastener is right in the middle. Strap clamps work best with the mechanical advantage taken at the 'toe', object being clamped.
    One benefit of the web, a little search will turn up good old brands, in usable or better condition, taking some of the pain out of expenditure.
    But work to a list, arranged by what priority suits you.
    It can double as an inventory, when time comes.
  18. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
  19. #10
    Congratulations Frank S - your Hold Down Clamp is the Homemade Tool of the Week!
    Another big week around here, but this one wins on ingenuity. We have seen tools made from rocker arms before, but usually as a spring compressor (here and here). This is clever, complete with "why didn't I think of that", and the use of the lug nut furthers the automotive theme.
    Wire Twisting Tool by orioncons36
    Sheetmetal Forming Tool by diy creative crafts
    Welding Third Hands by Andrii Pysarenko
    Belt Grinder Contact Wheel Attachment by anthonyget
    Spider Mandrel by neilg4dbn
    Wrench Size Reduction for Jam Nuts by Frank S
    Forge by ArmaBianca Creations
    Coolant Tray Filter by thehomeengineer
    Lathe Cut Off Tool by winkys workshop
    Hole Cutting Tool by mr_modify1
    Framing Square Stand by orioncons36
    Sandblasting Cabinet by fox craft
    Awls by Make Things
    Temporary Chuck Key by Frank S
    Space Saving Steps by Frank S
    Wire Twister by Andrii Pysarenko
    Pizza Cutter by Philip Davies
    Electric Bicycle by fawabros
    Lathe Stand by e_m_maker
    Chuck Mount Modification by Frank S
    Frank S - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 9th Homemade Tool of the Week. Here are all of your Homemade Tool of the Week winning tools. Congrats again
  20. The Following User Says Thank You to Jon For This Useful Post:
