Page 23 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 221 to 230 of 322
Thread: 1974 XS/TX650 rebuild
  1. #221
  2. #222
    Oct 2015
    th62's Tools
    I thought I’d make one more video before tearing the bike apart. This one deals with carb syncing with a manometer.
    This manometer has a relatively large body of water, and the vacuum lines are fitted with a .6mm jet. This has the effect of slowing down the movement of water stabilising the readings and making the device extremely accurate. Just a miniscule turn of either idle screw or throttle adjustment screw greatly effects the fluid levels.
    I have great trouble with my fingers, so you'll notice me changing hands frequently trying to turn the adjustment screws. I also turned the adjustment screws the wrong way a few times, putting the levels out.
  3. The Following User Says Thank You to th62 For This Useful Post:
    asterix (Apr 21, 2022)
  4. #223
    Lake Tahoe
    IntheGroove's Tools
    You sure do know what you're doing...
  5. #224
    Oct 2015
    th62's Tools
    This is a new brake divider I machined up to replace the original. The original hoses were rotted, so I replaced them and did away with the two steel tubes that connect the hose to the calliper and the hose from the master cylinder to the divider. Unfortunately, the new hoses have the banjos on the same plain requiring the lower hose to be twisted through 90degrees to connect to the original divider, so I machined a new divider to get around the problem. The lower hose connects at the rear of the divider, as does the brake light switch. The top hose connects to the side of the divider.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220425_17_23_08_pro.jpg   1974 XS/TX650 rebuild-win_20220426_10_42_14_pro.jpg   1974 XS/TX650 rebuild-win_20220426_10_42_29_pro.jpg   1974 XS/TX650 rebuild-win_20220426_10_50_08_pro.jpg
  6. The Following 3 Users Say Thank You to th62 For This Useful Post:
    asterix (Apr 26, 2022), olderdan (Apr 26, 2022), tonyfoale (Apr 26, 2022)
  7. #225
    Oct 2015
    th62's Tools
    A few hours is all it took - it's just a pile of bits that once was an almost complete bike now, just needed tyres and the seat covered. Going to be a big job polishing all those bits again, any volunteers???
    A couple of mods on the frame to do: Remove the coil and flasher mounts then repaint along with tank, guards, seat, trees and a few other bits. Not sure what paint to use this time. I used acrylic lacquer last time, but spilt some petrol on the tank and it stained it. Painted heaps of tanks with acrylic lacquer before but never had this problem, either the paint is different or the petrol is. Don't really want to repeat the exercise.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220510_15_46_38_pro.jpg   1974 XS/TX650 rebuild-win_20220510_15_46_46_pro.jpg   1974 XS/TX650 rebuild-win_20220510_15_47_14_pro.jpg   1974 XS/TX650 rebuild-win_20220510_15_48_20_pro.jpg   1974 XS/TX650 rebuild-win_20220510_15_50_35_pro.jpg
  8. The Following 3 Users Say Thank You to th62 For This Useful Post:
    asterix (May 10, 2022), Rikk (May 10, 2022), tonyfoale (May 10, 2022)
  9. #226
  10. #227
    Oct 2015
    th62's Tools
    Not from a service station.
  11. #228
    Oct 2015
    th62's Tools
    Applied the final coats of acrylic lacquer to the tinwork and some ancillaries this afternoon, didn't come out as clear or as good as I hoped, but acceptable I guess. I'll give it a few more days then sand the tank and spray over with 2k clear. Not the done thing, technically, but plenty do it, so we'll see how it goes.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20220611_15_41_31_pro.jpg   1974 XS/TX650 rebuild-win_20220611_15_42_30_pro.jpg   1974 XS/TX650 rebuild-win_20220608_16_20_11_pro.jpg   1974 XS/TX650 rebuild-win_20220611_15_42_23_pro.jpg
  12. The Following 2 Users Say Thank You to th62 For This Useful Post:
    asterix (Jun 11, 2022), Rikk (Jun 13, 2022)
  13. #229
    From what little I still remember about painting with lacquers was there was a lot of rubbing to ever get the shine to really pop.
  14. #230
    Oct 2015
    th62's Tools
    Depends on your technique. The tinware in the picture is straight off the gun. This was my first paint job on the tank, again, straight off the gun.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-tank-top.jpg   1974 XS/TX650 rebuild-tank-side.jpg
There are currently 5 users browsing this thread. (0 members and 5 guests)
