Page 29 of 33 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 281 to 290 of 322
Thread: 1974 XS/TX650 rebuild
  1. #281
    hemmjo's Tools
    VERY VERY NICE!!!!! A labor of love for sure!!!!
  2. #282
    Lake Tahoe
    IntheGroove's Tools
    That is awesome!!!
  3. #283
  4. #284
    Oct 2015
    th62's Tools
    An engine removal thingie I made. 'Thingie' is a technical term for engine crane. XS650 engines are a very tight fit in the frame, only mms to spare, if you want to work on anything aside from the clutch and alternator,the engine must be removed from the frame.
    The Thingie works quite well: Lifts the engine and tilts it forward so it can be rolled away from the frame without scratching or damaging the paintwork.
    The thingie also doubles as a work stand for top end rebuilds.
    When I've finished with the current work, I'll modify the stand so the engine can be mounted longitudinally in the thingie and rotated upside down to disassemble the bottom end.
    Once the motor has been disconnected from all electrical inputs and front, rear and top engine mounts removed, the motor can be removed from the frame in around 5-10 minutes.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-1.jpg   1974 XS/TX650 rebuild-3.jpg   1974 XS/TX650 rebuild-4.jpg   1974 XS/TX650 rebuild-win_20231014_16_00_29_pro.jpg   1974 XS/TX650 rebuild-win_20231014_16_00_42_pro.jpg
    1974 XS/TX650 rebuild-win_20231014_16_01_53_pro.jpg   1974 XS/TX650 rebuild-win_20231014_16_02_39_pro.jpg   1974 XS/TX650 rebuild-win_20231014_16_02_53_pro.jpg
  5. The Following 2 Users Say Thank You to th62 For This Useful Post:
    faniep (Oct 25, 2023), tonyfoale (Oct 14, 2023)
  6. #285
    Lake Tahoe
    IntheGroove's Tools
    Very nice. Works perfectly...
  7. #286
    hemmjo's Tools
    Well that sure did take a bit thoughtful creative thinking!!
  8. #287
    Sep 2018
    Wow, such a simple thingie ! I assume that just popped into your head and was made in an hour.
  9. #288
    Oct 2015
    th62's Tools
    Some single use thingies: A cam chain holder to stop the chain dropping into the sump all the time. Better than string or wire because the motor will turn over.
    A TDC finder. Made of an old plug which I threaded M10 internally, screwe a bolt in place, drilled and tapped that and screwed in a long M6 bolt.
    The degree wheel is held in place by three rare earth magnets, it has marking for TDC and other markings 5 degrees apart up to 40 degrees. The short piece of tube, fits in the central hole and is a tight fit around the socket for centering. Once centred, it's removed to give the socket a little wriggle room.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20231024_16_19_16_pro.jpg   1974 XS/TX650 rebuild-win_20231024_16_22_37_pro.jpg   1974 XS/TX650 rebuild-win_20231024_16_22_24_pro.jpg   1974 XS/TX650 rebuild-win_20231023_16_12_23_pro.jpg   1974 XS/TX650 rebuild-win_20231023_16_13_17_pro.jpg
  10. The Following 4 Users Say Thank You to th62 For This Useful Post:
    drivermark (Oct 25, 2023), faniep (Oct 25, 2023), Jon (Oct 26, 2023), tonyfoale (Oct 24, 2023)
  11. #289
    Oct 2015
    th62's Tools
    When I got the bike the cases had been damaged (read - rooted) by an errant chain. Along with that, the alternator cables had also been cut by the chain and the chain deflector, or whatever you call that thing residing over the gear lever pivot, was also stuffed.
    Rather than stick with the original design, I turned up a one piece Delrin bush which slides over the gear lever shaft. Rather than hide the alternator cabling behind the chain deflector, I rerouted the alternator cabling so it is underneath the gear lever shaft and held in place by a P clamp on the starter gear cover.
    You may also be interested in making rubber grommets. In the pic you can see the rubber grommet through which the alternator cabling is routed. These, and other grommets, are super easy to make: A fibre cut off wheel and belt sander being all you need. Plus a good set of eyes, or in my case - glasses! The fibre cut off disks are good for cutting the slot, and either the cut off disk or belt sander to shape the outer circumference. Spinning rubber on a lathe does not work well, trust me!
    After shaping the grommet, the groove or slot in the grommet is best made by mounting it on a piece of round stock and rotating it against the cut off wheel. Cut of wheels are generally available in two thicknesses 3mm and the much thinner ones used on small angle grinders. Obviously a good, solid rotating base will result in a better groove or slot. With a bit of practice , they are easy to make and come out as good as a bought one. In Oz, blocks of rubber are available from Clarks Rubber. I'm sure in whatever country you live there will be similar stores.
    Never buy what you can make.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20231018_11_18_32_pro.jpg   1974 XS/TX650 rebuild-win_20231018_11_18_40_pro.jpg   1974 XS/TX650 rebuild-win_20231018_11_21_20_pro.jpg   1974 XS/TX650 rebuild-win_20231018_11_21_27_pro.jpg
  12. The Following User Says Thank You to th62 For This Useful Post:
    RetiredFAE (Oct 30, 2023)
  13. #290
    Thanks th62! We've added your Cam Chain Holder to our Motorcycle Engine category,
    as well as to your builder page: th62's Homemade Tools. Your receipt:
