Page 32 of 33 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 311 to 320 of 322
Thread: 1974 XS/TX650 rebuild
  1. #311
    Jul 2018
    Flora, MS
    Floradawg's Tools
    A beautiful bike! What are the cylindrical parts mounted at the top of the rear shocks?
  2. #312
    Quote Originally Posted by Floradawg View Post
    Air or nitrogen sealed pressure chambers. The gas pressure is to stop or reduce the tendency for cavitation in the damping oil. This is very common with any quality shocks but some incorporate the gas chamber within the body of the shock and some do it in a remote cylinder connected by a hose.
  3. The Following User Says Thank You to tonyfoale For This Useful Post:
    Floradawg (Mar 18, 2024)
  4. #313
    Oct 2015
    th62's Tools
    And some of the cheaper ones are BS, just for show. Fortunately, mine are real.
  5. #314
    May 2021
    Georgia USA
    Very well done! Your design concepts, even if they didn’t work still benefitted us all. I certainly learned a bit from your hydraulic clutch attempt!
    Thank you for sharing your beautiful project!
  6. #315
    Oct 2015
    th62's Tools
    I made a fuel distributor a while back, its function was to level the fuel when the level in the tank dipped below the level of the tunnel and also to neaten things up. ,I had two online filters feeding fuel into the distributor.
    The filters just kept cracking and leaking, so I decided on a combined fuel filter/distributor and this is what I came up with. The unit sits between the manifolds I made a while bike and is mounted in rubber grommets on a bracket attached to the cam chain tensioner.
    The filter is sintered bronze and the body 6061. The bore is 18mm at the top to seat the filter and O ring, then expanded out to 23mm. There are three 6mm brass barbs pressed into the lower section, two for inlets for fuel, the third for purging debris. The top cap is retained by two M4 screws and is a push fit over the lower body, an O ring sits in a recess around the filter for sealing the top cap to the lower body.
    Two 8mm brass barbs were pressed into the top cap and they feed the carbs via short fuel hoses. The cap is drilled 10mm underneath leading to a 5mm cross drilling which lead to the two brass barbs.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-win_20240519_14_56_24_pro.jpg   1974 XS/TX650 rebuild-win_20240519_14_56_50_pro.jpg   1974 XS/TX650 rebuild-win_20240519_14_59_02_pro.jpg   1974 XS/TX650 rebuild-win_20240519_14_59_33_pro.jpg   1974 XS/TX650 rebuild-win_20240518_14_07_58_pro.jpg
    1974 XS/TX650 rebuild-win_20240512_08_42_49_pro.jpg
  7. The Following 2 Users Say Thank You to th62 For This Useful Post:
    Jon (May 21, 2024), tonyfoale (May 21, 2024)
  8. #316
  9. #317
    Oct 2015
    th62's Tools
    Deleted. Moving on.
  10. The Following User Says Thank You to th62 For This Useful Post:
    asterix (Oct 14, 2024)
  11. #318
    Is the compression loss equal on both cylinders?
  12. #319
    Oct 2015
    th62's Tools
    Yep, within two or three psi.
  13. #320
    olderdan's Tools
    If the piston ring gap is a little too small it can cause the ring to distort if the ends meet as it gets hot. Nothing to lose by increasing it slightly, as the rings wear it gets larger anyway. You probably gapped them to spec but the problem you have exists so worth a try?.
